I have a quick question as I am putting my carb kit in...the top of the needle, where the pivot arm slides underneath....is that gap standard or do you have to adjust the pivot arm any? I know that I need to adjust the pivot arm on the other end to make it flush with the body of the carb...but what about the other end? The reason I ask is because there is some space between the top of the pivot arm and the needle, so that when you press the other end of the pivot arm down, it goes down a little before it lifts the needle up any...
I hope this question makes sense...
