Sounds like you burned the tops of the pistons, I thought that the Champions might have longer threads, causing the plug to contact the piston. From what the Doc says probably not.
Check the compression, if you have good compression, 120 or better both cylinders.
Will it start with the NGK plugs? Just see if it starts, don't leave it running.
Lou
