Landen Koch
I need to remove the pump support plate to shim behind it because my alignment tool is sitting way low in the thru hull fitting so I need to get it centered and then shim the motor. I know I will need to remove the intake grate and the bolts and hosing inside the hull, but do I need to remove the ride plate or any bolts on the bottom of the ski. It’s a 2000 seadoo xp
