If your seadoo wont turn over with the plugs in take them out & crank you may get some water shooting out of the spark plug openings. if you do get a good spray of water then keep turning the engine over for no more than 10 seconds at a time till all the moisture is gone. Then if you put the plugs back in & it still wont turn over with the plugs in.
Make sure you have a good battery with a good charge , with the boat on the trailer
prop the front tongue of the trailer up so that the front of the boat is at least a foot higher than the back of the boat. then try to crank the engine watch to see if water starts to run out of your exhaust tail pipe. if so you the engine was hydro locked try and crank the engine till all the water stops coming out of your tail pipe then you should be able to turn the engine over with the plugs in.
