rgardner928
This is going to be long...
Does anyone know the spark plug model number for a Rotax 717 (a pair of them in a 97 speedster)
So I now have in them NGK BR8ES. But I keep having fowling issues. I use the choke to start and run it close to balls to the wall. But I also do some slow speed riding at times. I keep having one engin, at times stall out when at low speeds, even after riding balls to the wall. And sometimes it never starts again. I'm getting frustrated with this. If I change the plugs, it runs fine again. I use the boat for an hour or two one or 2 days a week. I spend more time on the water fucking with engine stall issues and start or staying started then I do enjoying them. The plugs should last longer then a month before needing to replace plugs again.
So I did some research and learned this,
"NGK indicates the heat range in the middle of the plug number. For example, BCPR6ES-11 has a heat range of 6. (The number after the “-“ is the gap.) NGK plugs are colder the higher the number, hotter the lower the number.
Starting with part # BKR6E-11 (heat range 6),
a colder plug would # BKR7E-11 (heat range 7),
a hotter plug would be # BKR5E-11 (heat range 5)"
Now knowing this a BR7ES would burn hotter than the the ones I have now. I do understand too hot can hurt my pistons, seals and other components (all factory) and burn what's called too lean. But I'm not also not moving to a BR1ES..I'm only going down one, "maybe" two.
I'm thinking about going to the 7 as it's a little hotting and should help with preventing the fowling I'm seeing. I also know earlier engines than my 717 did run with the 7 prior to 8's in them now. So I believe it should handle a one or two digit hotter plug.
I'd still watch my plugs over time to see if I'm getting too lean. But with everything I've said, in theory, wouldn't the 7's help in my situation?
