Hey everyone, new member after lurking on the forum for a year and learning so much already from everyone. Finally having an issue I wasn't able to figure out from existing posts, here goes nothing
I have a 2011 GTI SE 155. I bought it at the end of last season, and at the start of this season I replaced the battery as the previous owner said the old one was inconsistent. After putting 4-5 hours on it this year, I had a situation where some water spray came in the front compartment while it was open and likely got some of the components wet. After that happened, the following issues started to occur on the way home:
- when driving back home at high speeds (40-50) the speedo would randomly shoot up to 60-70 (the ski tops out at 54, so impossible to get to 60-70) then the ski would "cut off". Slowing the ski down to 0, and then driving again would be fine until the same issue would happen again. I never turned the ski off in fear of it not turning back on in the middle of the bay
- Once I made it back home, the ski did not start again. Initially, the key was not recognized so based on feedback from the forum, I changed the DESS post first.
- The ski still did not start after changing the DESS post, but I did start hearing a weird humming noise coming from the fuel pump. This humming noise comes on even with the key not being recognized (
- I changed the fuel pump to a new OEM part and the issue continued, the key still did not get recognized the the fuel pump makes the humming noise.
- After further searching on the forums, I then changed the starter relay solenoid as some said those could go bad. That still did not fix the issue, key still not recognized and fuel pump still making the humming noise
I have to disconnect the battery or unplug the fuel pump to stop the noise and have the infotainment screen stop saying "reading key". 1 time in the last 50 or so attempts did the key get recognized, and started right up. I checked all the fuses and relay and they all appear fine, and have cleaned all terminals that I have access to in that front compartment.
What other areas should I be looking to test? Since it did start once, (after replacing all the parts mentioned above), is it possible there is just something loose or rubbing somewhere causing a short or not full power to be sent through? Could the ECM be bad? Any feedback would be amazing and happy to share any further pictures or videos of what I am seeing
