Great. I won't modify them. I have to trim the valves because of the 1mm overbore.I’m still running the smooth ones in my ski with no issues.
Why would you want to coat the internals of the exhaust? The carbon and oil will do that for you.
Did you check the welch plugs on the headpipe? Also get some clear on that purple mister!
I cut the window and made the connection for the fuse but the sender is still not working. Lots of corrosion on the board. I sealed it back up and I am deciding if I want to purchase a used unit that works. I think having a fuel gauge is.... handy. LOLYou cut a window in the side, the top doesn’t come off.
