Sorry... I just looked up the 99... and the MPEM has the junction internal.
If you look at your coil... and it says "CDI" on it's label... then you can tie the "Black/red" wire from the mag, to the "White" wire on the cdi/coil pack, and see if you get a spark, then the rev-limiter inside the MPEM is gone.[/QUOTE
see the black/red wire coming from the mag i cut that then got a extra bit of wire joint it too it then spilt the plastic on the white wire and bridged it in.have i done this rite
