spamcho
Hi there,
i have a problem with my seadoo GTI 2001 717cc one carb, the engine is rebuild it work perfect on idle RPM, when press the throttle wan’t rev up, but if pull out the choke for 1 sec, the engine rev to high rmp, if i ride it from middle to high rmp don’t have a problem, but from idle to middle rmp is impossible without pull out a choke.., the carb is rebuild it, what can i do?
thank you
thank you
