Repaired my lanyard switch post
I ran across this thread right after my lanyard post broke off on my 1996 HX last month.
Since I wasn't going to be able to get the $135 switch in time for a houseboat trip, I was already planning on improvising a solution.
I dismantled the factory switch. The rubber switch "clicker" is fine. So if you still have the plunger and spring parts, then you can reuse everything.
The fix that I came up with required obtaining an old school toggle switch from a local electronics shop.
What is special about the switch is that the threads must be the same pitch as the plastic nut (for that factory look).
It must have a metal body - the threads and the top plate it mounts to must be a single piece.
It must be readily disassembled to allow the top half of the switch body to mount to the bottom half of the Seadoo switch body.
The threaded section must be roughly the same height as the factory plastic threaded section.
Here is a photo of the switch I took apart to do this:
I had to drill out the center to make the inside diameter wide enough to slide the plunger through - make sure to file it out so there are no rough burrs inside.
I used all kinds of zip-tie action to secure the new metal part to where the plastic plate/threads used to be. It takes 8 hands to hold the plunger and spring in place while stacking everything back together.:ack:
In theory you could use more professional looking fasteners than zip-ties......epoxy, rivets,etc.
But the repair took all of 15 minutes of fiddling around.
And I got to use my HX on the houseboat trip after all.
