Rxt rpm and hesitation problems
rxt13
I have a 2013 rxt bought new last year. I guess to start from the beginning I had 22 hrs on it last year and it started to loose speed it ran about 55 from the normal 68-70 I took it back to dealer as its under warranty they said plugs were bad replaced them and everything was fine it had a hint of hesitation again around the end of summer but couldn't replicate it often it was very random I had them look into it they never could find anything they winterized it and started it this summer. When I picked it up this year they told me it sounded a little funny once or twice but they couldn't replicate the problem again and that it is probably the gas going bad and it probably burnt off then and it should burn fine just do it quick. So I went out that weekend it ran fine no problems at all the following weekend it had a little hesitation as it did last year I came back to shore looked everything over tried again and it was fine never hesitated again that day or the next. 3 weeks pass and I ride again and I can't get over 40 w random burst to 45 (4950rpm w burst 5250rpm) I changed plugs/siphoned the gas tank refilled it/ check injectors appear to be doing fine they do spray 2-3-1(that's the plug number) ran seafoam thru it and 3/4 tank gas check bolts around the cone (3/4 of a turn all I could do) and tightened my steering which was extremely loose nothing changed even slowed as I rode. Any advice would be appreciated thanks
Jeff
