19 gtx 230 stays at 6k rpm ??
Was riding the ski avg 60. For a long time, while playing music. Arrived to the ramp load it up to the trailer after an hr or so, drove myself to a different boat ramp started the ski no issue. Ibr light came on and off. Turned the ski off and waited to clear the cluster and began the ski again. It rode up to 6k rpm where it lead me to 40mph. After a while turned the ski off and hanged out for an hr or so. Turned the ski again and it only let me ride up to 6k rpm. Spark plugs were changed the day prior to pulstar spark plug. Ran the diagnostic the next day. What may be the cause of it? I opened the ski everything looks fine. It has 111hrView attachment 67733
Not to many peeps running pulstar plugs on the forum. If you were having this problem with stock plugs we would say change them.
Both codes share share symptoms with the talking to the cluster, make sure your cluster connector is not corroded or damaged. Then your IBR connector and ECM connectors going to the cluster and IBR.
