Rxt ibr, is and vts issue after ecu replacement
DanielX
Hi everyone!!
I.have a problem with my jetski...
The old ecu just stop working, and I order a brand new ecu. I installed it, married it...
But the is, the ibr and vts don't work...
I have a mega tech licenses, I'm thinking about just change some parameters there and everything will be done... but I don't know what's number or what coding change
Anyone can help me?
I doesn't have any fault codes... the ski starts and works perfectly,
Just the ibr, is and vts features are not working,
The display don't show where is supposed to be the IS level..
That part of display is blank...
Note this, if I change the ecu with another same from a friend it works perfectly including is ibr and vts features
Thanks!!!!
I would confirm you obtained the correct ECU/MPEM. Also, many skis that have the IBR systems replaced require the IBR get programmed to the MPEM. I would look into that as well.
Thanks for the replies...
I'm going to make a " clear as new" procedure... to see what's Happen.
I have a doubt:
In the buds interface, at the left side where appears vin, engine and model numbers..
I got the model field in "000000"
I think this number is necessary to determine the exactly specs of the ski, if someone have those numbers I would be very grateful if he gave them to me... :D
I have a doubt:
Correct the ECU does not know you have IBR. What year/model is the ski?
Seems like ecu doesn't recognize ibr, is, and vts systems..
is a 2010 year
I pick this screenshot from the web, the 3rd field on the left red squared is "000000"
Thanks for your reply
Model 00034AB add that in MT then switch to all product dealer and it should find the correct flash. Or scroll through the update flash list.
Good evening...
i got the ibr and the vts work perfectly....
But can't get the intelligent suspensión read by the buds.
I'm thinking about a corroded connection on the suspension control module...
Does the engine number on the ecu... necessary to get this work?
The field on the buds is in blank..
Update:
I got everything work again, the connector on the IS module was corroded, bad seal...
Take care of your silicone seals and add some dielectric grease on all of them..
Lot of thanks everyone!
Good evening...
Update:
Great news. Glad everything is working again for yah.
