RX Fuel line replacement
I've only done it once so really can't visualize it. I pulled up the step by step instructions hoping there would be a picture for him there but in step 1 it just says remove all the linkages and the first picture has the cars off.
Here's a link to BRP parts catalog, search for your ski, there's a pictorial of your carbs. you can see the linkage details. I can't find detailed instructions on exactly how to remove the linkage. You should be able to lift the carbs. so you can see the connection easier. This is really not that hard, if you look closely you can see how the cable is attached.
Mark or count the threads on the adjustment nuts so they go back in the same place when you reattach the cables.
http://epc.brp.com/SiteMods/BRP_Public/BRP_Public_Login.aspx?ReturnUrl=/Index.aspx
Lou
Lets call it a night. Do a google search for Mukini Carburetor 41N (I think that's your model). See if you can find more detailed instructions. Everything I can find just says remove the choke and throttle cables.
I don't want to sound condescending, but if we can't get past this step, maybe you should just put the carbs. back on and get a professional. It gets harder from here.
Lou
Nah..I understand...Just can't figure out what to loosen so the cable comes clear...but will look again tomorrow...Thanks...
Im a newbie and just did mine 3 days ago.
The linkage you are talking about going under the ski is connected to your oil pump.
It does not come undone from under the ski. It is connected to the side of your carb and unscrews from there(the tension is realeased from there). It is a long (1") screw that has a nut on the bottom side of it.
You loosen the nut and unscrew the threaded part.
So ...
Follow the linkage wire from under the ski you arre talking about. Follow it to where it connects to the side of the carb.
It will attach to the carb bracket. Loosen the nut and unscrew it from the bracket.
Do what Lou says and count the threads to make sure it goes back the same way.
All these connections are spring loaded. You have to manually turn the choke/throttle/oil linkages to release the tension and then take the cable loose.
Good luck.
Also, i removed the cables before I removed the carb. Put the carb back on, remove the linkages, then removed the carb.
I think you are going to have trouble putting the linkages back on properly. As i said before you have to manually turn the choke lever to release the tension, then remove the cable. You can do it.
Put the carb back on then remove the cables/linkages. This way our rights and lefts and ups and downs are the same when communicating.
When you remove the linkages, then take the carb off.
One more thing. When cleaning the carb there is a Youtube video I found helpful.
Its not the exact same carb, but close enough to show you where the filter is.
Boyd,
Thanks for the help, that's the diagram I was looking for.
Ashnic, take a look at this link http://www.atlanticjetsports.com/pdf/Mikuni_sbn_rebuild-kit.pdf
Can you see where the cables are connected, it doesn't show the cables but the throttle cable connects to the half round part near part #9, push it back to release the tension.
The choke cable connects near part #10 push the butterfly closed to release tension.
Your carb. is BN44
If you want to go the the main page (there's one too many http's in the above link), use www.atlanticjetsports.com/jetting.htm
Thanks again boyd, you've been a great help.
Lou
Glad to help. I appreciated the help you gave me when I was doing mine.
I can also see where zip ties would be easier. I used hose clamps but it was awfull tricky hoding that clamp and turning the drive. Pulling on a zip tie would have been much easier.
Thanks to you Lou and all kind people like Dr. Honda for saving us "wanna bee mechanics" some serious $$$$ and time.
Boyd
Boyd, Thanks for the compliment and glad to help. I'm really just a shade tree mechanic myself. I'm just passing on information and skills that I have learned from people like. Dr Honda, Seadoosnipe, bill86e, and others. These guys are the real hero's of this forum.
Lou
Had some others things gong tonight and didn't get a chance to mess with it...last thing I want to do is work on it and be aggreavated..Thanks for the extra info boyd...and Lou can't say enough...sometimes I think I might just overthink it as I am trying to figure out the mechanics of it instead of doing the obvious...will hit it hard this weekend...will keep you posted..
I'm going to the lake tomorrow, probably be there most of the weekend, I'll check my EMail from time to time.
Lou
Well like I said...I was overthinking it...Got the carbs out and proceded to check everything out on the carb...filters were black, lots of junk in them...got them cleaned up and rest of carb...will start putting everything back together and replacing line tomorrow!
Carb Rebuilds
I just did mine, I was able to keep the linkage between the carbs on and turn the carbs to assess both sides. The primer pump linkage came off when I rebuilt the pto side. These carbs are doing great.
You should take off the exhaust to make it easier to get to the carbs.
Also, the rebuild kits come with fuel pump rebuild stuff with new check valves. Take your time, 1 side at a time. I also hit all orifaces with carb cleaner.
FYI when you flip the carb over be careful not to put too much weight on the pulse nipple on the mag carb, I did and broke mine off. Fortunatally I am a plumber and it was brass and I was able to solder it.
Well got everything back together..fuel selector valve was dirty as all get out...some gunk in the tank...all lines replaced..took a while to finally get gas to the carbs...but when it did fired right up and sounds pretty good...hope to take to lake tomorrow and give her a try...
Took ski out...ran really good, out of the hole a little doggy..idle was way down around 5-600..going to adjust idle tomorrow...
Congratulations, glad everything turned out O.K.
Adjust the idle for about 3000rpm on the trailer, it should idle about 1500rpm or so in the water, I like mine just a little higher, 1600-1700 so the ski doesn't rattle so much.
I would add some marine stabil to the gas for a couple of tanks, just to clean out any residual crap in the system.
Lou
