Stop repeating yourself, we get it. Unfortunately you do have an issue of a stuck throttle butterfly, incorrect idle speed, air leak, etc. as for the electrical, you are on your own. Without having the ski in front of me to see how the swap was set up, I can't help you. Lou is right, you need to check your work because you did something to cause it to rev at start up.
