Rookie needs help/advice
OutlawBiz
Alright, let me apologize up front if this question is very stupid!
I just bought a 1999 SeaDoo GS sight unseen that is in immaculate condition with only 50-60hrs on it (owned by elderly couple at lake home).
Is this ski a 2 or 4 stroke!?
I am trying to determine what type of oil was used and how to proceed with adding my own oil etc.
the "GS" series is 2 passenger... and the "GT" series is 3 passenger.
It's a 2-stroke... with the 720 engine in it.
Just so he is not confused, the 717 and 720 are the exact same engine.
See here: http://www.seadooforum.com/showthread.php?40308-Are-the-720s-to-the-717s&p=178141#post178141
You could use any API-TC rated 2 stroke oil in that engine. (Mineral, Syntehtic blend, full synthetic). The higher horsepower engines require a full synthetic API-TC oil. The GS does not have that requirement.
PS. Should add that you do not want to mix a different brand of oil in with what is already in it. If you do not find out what oil is already in it, you should clean the system out before adding new oil.
I called and asked the owner what "kind" of oil he used in it. He said he honestly didn't know. He said he never had to add oil while he owned it...that never "used" oil!? He said he figured whatever oil he did buy was the "good / expensive" stuff becasue he didn't typically "skimp" on stuff like that.
So, I called my local SeaDoo dealer and spoke with the service dept. Mechanic said if I was unsure which kind was used currently, to just wait until it gets "low" and then add my own good oil and I would be fine.
SoI got a mechanic telling me to just add good stuff when it gets low, and I have others telling me that the whole system needs drained / cleaned etc.!? Who do I believe?
Is it realistic that this ski doesn't "use" oil!? Liek I mentioned before...supposedly has 50-60 hrs on original motor and showed a 145 compression on BOTH cylinders.
Sorry so many questions...I've ridden PWC's plenty...just never OWNED one so I am trying to learn. Thanks.
As far as the oil business goes it's just a good precaution to completely drain the system. You could wait till it gets low then add some and you are probably on the good side of the ratio for that working out. But over time it has been proven that some oils mixed together will gunk up. If this were to happen it could clog your oil-injection line and next thing you would know its time for a bunch of new parts. So, when I changed oil I completely drained the tank and put new in.
Is "draining the tank" a difficult proceedure or is it relatively easy!? Is this something that should be done by a dealer or can it be done in my garage?
I change fluids on my Harley, cars etc. so I don't consider myself to be completely mechanically challenged...but, I have never owned or even "looked under the hood" of a pwc so I have NO idea what I am up against!
If it is a fairly simple thing to do, I would attempt. If it is more complex...I would take to a dealer.
In general...how often do you need to "add" oil to these things!? Once a year, once a month, every trip!? Is there just an oil level indicator that one needs to monitor and add as needed type thing!?
I purchased, pulled home, backed into garage and pulled the cover off this thing...that is IT! It has been too cold/rainy to get it out to the lake and I have been too busy at work to "inverstigate" the motor etc. to even know what I am dealing with.
As Watson said, it is a good practice that most people follow because some oils do not mix well together and most DIY'ers don't want a blown engine to deal with.
It is not too hard to do, but the PITA factor depends on the model of ski as some have little room to manuever arms/hands/wrenches/etc. You drain the tank, remove, clean out, change filter, reinstall everything, and then bleed the system. The GS isn't exactly one of the easier ones to do this on, but is still something you should be able to handle.
It is also good practice to change the small injection oil lines every couple years and inspect them often, as they tend to get brittle/crack and are often the reason for a lubrication failure. They run from the oil pump and down under the carbs.
And while we are on the subject of what you should do, if you have gray fuel lines, you will need to replace those as well. They corrode on the inside from the ethanol in the gasoline and clog the system/carb filters up. This could lead to a blown engine.
The one thing I find completely ODD is that the previous owner said he never had to add oil to it and it has 50-60 hours on it?!?! Did he only own it temporarily and only put a few hours on it? And how does he know if he is "skimping" or not if he doesn't even know what he bought?
The ski DOES need oil. But, you can block off the pump which would require you do you own premixing in the gasoline (you have to add oil to the gas you put in).
