Year model....
They did make a 1988, but like you said, the year isn't important. But, if you'd like to be certain, look at the back on the right hand side. You'll see a series of numbers. This is the hull identification number. The last 2 digits specify the year.
The ride plate will not change anything for you and this ski. If you look at
part #18, you'll see this is one piece that will affect your pumps mounting. That ring you see is the seal ring for it.
Your problem is going to be the position of your nozzle. You don't have a VTS so we'll have to figure out why your nozzle is obviously out of place.
Sometimes, this is in the linkages but you have no nozzle attitude linkages that I know of.
So, I think it's possible that your pump was removed and shimmed.
You might take a pix of the back side fo your pump and post it, let me take a look. Or, you'll need to set the ski on the trailer flat out, even plane. Then, stand back and look at the attitude of your nozzle. If it's aimed slightly up, you need to find a way to lay it out level or even with a slight downward angle.
This problem can also be caused by weight displacment. If you've loaded additional equipment toward the rear of the ski, it will cause porpoise. If your riding a second rider or if your own weight is over 180 lbs. and your riding with your center of gravity to far aft.
There are several reason for this too happen. If you can't answer any of these issues that I've listed, you can try to put a little nose weight in the ski to help hold it down.
