Sportster-2001-951C-Stock
Make dang sure that low speed circuit inside the carb isn't clogged, it can be a real bear getting the junk out of there. I agree the aftermarket carb kits don't make the cut, some of the parts are inferior and if you use them you can hear that finicky Mikuni laugh at you while it acts completely stupid.
I'll say it again, make certain the low speed circuit isn't clogged, not even a little bit clogged! Then clean it again.
"It seems no matter how far or what direction I turn the screws nothing drastic happens. "
The idle mixture fuel comes from the low speed circuit, idle mixture adjustment doesn't work properly if there's junk in there. It also will be difficult to dial in if those aftermarket parts are screwing up the fuel metering diaphragm action. Check pop-off to confirm it's close to spec, not in outerspace. Correct spring and metering lever position to fine tune both within 1psi of the other. Never bend or modify the spring in any way, this ruins it.
This symptom sounds like lean hesitation, clogged low speed circuit causes lack of fuel (thus lean) assuming your carb parts are functioning correctly.
If it starts and runs on the trailer then before you can diagnose further with any confidence, the jet pump must be submerged. This can be accomplished in a testing tank, on the trailer at the boat ramp or in the neighbors swimming pool, but not on the trailer on dry land.
