Ok here's what i did, disconnected the 3 yellow wires from the mpem and fitted an external rectifier off a honda fourtrax and fitted the green wire to ground and the red wire to the starter solenoid where it connects to the battery.cleaned all electrical connections and terminals.
disconnected the red and the black wires in thr rear electrical box,,,figured they were the internal rectifier wires i tried dissconnecting them but the ski wouldnt run,
got the ski running ,,finally no more 12v low warning and everything is ok,,checked for ac voltage at battery got a 0 reading,,so everything seems to be good,,will take it out and test it later this week.
do you guys think this rectifier will hold,,,do its job.or is it too small for the ski being of a honda fourtrax ???
and if the rectifier by any chance passes ac voltage,,will the 12v low warning light up and beep??
thanks for your time and help.
