I would like to introduce myself,  I live in Solomons island md and I just purchased 2 1997 seadoo gti's with the 717 motors.  I have owned boats my whole life and I am very mechanicly inclined working on my own cars and straight inboard boats, and outboards.  I usually buy bota in need of work and fix them up.  I am new to the jet ski world and know nothing about them.  My current watercraft inventory is:
1997 22 shamrock
1999 palm beach 171
2- 2004 honda aquatrax jet skis (just bought last month)
several small row boats
2- sea doos 1997 gti's
The jet skis I bought both need work. I will start with jet ski #1:
jet ski 1#. The top end of the motor was off, the pistons seem rusty, piston walls rusty, and the motor seems to be siezed (I put a chain wrench on the harmonic balancer and I cant get it to move). From the looks this has been sitting for 4/5 years like this. I pulled the motor out and have it on a bench. I would like to possibly get into buying jet skis and fixing them up eventually. I wanted some opinions on am I better buying a rebuilt motor, or buying some specialty tools, rebuild kit and doing it myself? If doing myself I was wondering how many guys have the crank turned down? Is it a judgement based on condition have it done no matter what? I believe in doing things right just wanted some opinions. Also what other areas besides the engine should I look at?
Jet ski #2: I hooked up a battery and could not get it to turn over. I pulled the plugs and the plugs were filled with oil. I was happy when I saw this because its been at least 4-5 years so at least the guy winterized them. I turned the engine over with the plugs out and oil was going everywhere. I kept putting towels over the top of the motor with the plugs out and turning it over and oil seems to keep comming out. I am use to marine inboards/ outboards where we shoot some fogging fluid in the cylinders and in the spring pull the plugs and turn it over for 15 secongs to blow the oil out. I think the motor is getting hydrolocked with oil when I put the plugs in. Eveytime I put the plugs in after a few turns the starter cant turn the motor. once I pull the plugs out it will turn. I also tried doing a compression check but because of all the oil it keeps going up to about 250 psi. Can somebody tell me why the oil is getting in the cylinders? I dont know how this motor was winterized, no info on them when i bought them. This ski also seems to have no spark. I cleaned the oil off both plugs, put heat on them and when I ground out both plugs I am getting no spark. I dont hear the beep beep sound when I install the kill switch but it turns the starter and the starter doesnt turn with the kill switch off.
Also how do you alighn the shaft when re-installing the motor? I have installed probably 10 straight shaft inboards and we use a feeler guage and adjust the motor mounts until the gap is equal all the way around. I dont see any adjustments on these motor mounts.
Any advice would be appreciated I hope to get these running by spring.
Thanks
KMD
			1997 22 shamrock
1999 palm beach 171
Thanks
KMD
