Thanks for the reply,
If understand you right, the spark plug boot will just unscrew from the wire and then I should clip the end of the wire? I was thinking that if i could get the boot off the wire it would fit through the hole on the electrical box. If I end up having to clip the cable itself I dont think I will have enough cable to reach the spark plugs due to it being a tight fit already. I looked at disconnecting the spark plug wires from inside the electrical box where they attach to the grounding board, but I am not sure how i would go about doing that. I sure wish I had read the other posts on why the electrical boxe covers wouldn't snap into place on other ski's. Then I wouldn't have broke the clip off the box cover trying to force it back into place. Thanks again for the reply, I have learned a lot from all of your posts. One last question. Do you have any tips on the step sequence for re-installing a steering cable? If so, maybe it would save me some time and frustration in trying to determine weather or not I did it right.
Thanks
