adjustment
Screwing it down will allow it to stay wide open[ flow] longer,but the water should preheat at the lake so it might seem warmer,on hose you can`t let it run that long.I just got home from a test morning,my entire exhaust stayed cool/water was warm,I`m at red Dot flush to rave body.also you have water pressure at hose,engine gets water from pump/take a good flashlite and look thru pump[under boat forward looking aft.]@ 12 o`clock you`ll see the spigot the pump fforces water thru,mine had a couple of peebles stuck in it.My Lake Test Revealed my engine rave[pto side] is drooling oil,think I might need to replace bellow or put a zip tye on lower part.
