Hi, I just inherited a 2012 GTX 155. The previous owner let it sit unattended for more than a year. He says it has very low hours (40) and cosmetically it looks in very good condition. However, the cover had a rip and the hull was full of water. This is rain (fresh) water from neglect it so I guess that the engine has no water in it. The water was deep enough to completely cover the battery (located under an access hatch at the rear of the hull).
I drained the water and let the ski completely dry out for about two weeks in the hot summer sun. Put the key on and got absolutely nothing. So, I bought a brand new fully charged battery and installed It (cleaning battery connections at the same time). Now when the key is on and start button pressed all the dash lights on the outer two (of three) dash panels light up and cycle back off again one by one. Then only the green GPS light stays on. The centre all digital display dash panel remains completely dead throughout all this process. The ski beeps once when start is pressed and than steadily continues to beep once every 15 seconds or so. Apart from that there is no response, clicks or sounds at all - it’s dead. The problem is I guess electrical but what / where ?
So, before venturing off to the “... let’s just replace everything“ dealer, what should I check and in what order? Any ideas will assist. I have a working GTI 155 if swapping parts to check will assist.
