dsw222
I recently installed a Sony CD deck in my 97 Challenger 1800. The deck was purchased 2 years ago but kept brand new in the box until recently, due to lack of time and problems with my engines that have finally been resolved.
The install went great and the radio and speakers sounded amazing. However when I had it out for a test run, I did not have the rear mounting bracket attached (stupid). I hit a wave and the radio fell into the storage compartment. I pulled it out, put it back, and it still worked fine.
However, after that incident... every so often, the radio would turn off for a few seconds then turn back on. This would usually happen when turning the volume knob. Finally the radio quit working completely and does not even appear to be getting power.
I figured that something was internally wrong with the head unit due to the drop, so I bought another Sony deck (newer model because the old one is no longer being made). This was a direct replacement, so I pulled out the old one, put in the new one, and plugged it in. Nothing. It does not even appear to be getting power.
What could cause this? Possibly a fuse somewhere? I don't know much about the boat's wiring or where I should check. It appears that all connections on the wiring harness are connected fine.
I don't know if its related or not, but I noticed a black plastic connector with wires hanging down inside the OTHER storage compartment (on driver's side) which is not connected to anything.... could this be related? Or maybe its for an optional depth gauge that could fit in the blank slot on the dash? I never noticed it before so maybe it worked its way loose.... although I cannot find a place to reconnect it.
Any tips would be appreciated!!
Thanks!
Thanks!
