We have a big gouge in the bottom of the boat, just got quoted for 2800 bucks to fix it, is that possible. Its white fibre glass showing, quite deep, but not all the way trough. there is no leak, just exposed fibre showing. It was explained like this: the exposed fiberglass will slowly get spread apart and cause water to penetrate and turn the fibreglass spongy. It will slowly spread and cause even more damage. Does this sound right?
He said for about $75 he can do a quick fix and basically fill it with silicone and put a few coats of gel coat over top of it. And it will "stop the bleeding" of potential water penetration for the rest of the season.
Also, the seadoo is in the shop right now to replace wear ring. Turns out the damage to the wear ring also caused damage to the pump. The pump wear ring housing is dented and the new wear ring wont fit properly. The mechanic said hes trying to bang it back to normal grinder etc. He says hes trying his best but worst case i need a new pump. Where can I get a used pump if it is worst case scenario?
how much is a new/used pump???
