the most common problem with the older pumps is that corrosion gets between the wear ring and pump housing, this cause the wear ring to collapse a bit and lock the impeller
sometimes the rubber coating on the wear ring comes apart and jams the prop
you could also have a impeller shaft bearing failure too.
pulling the pump is pretty easy, a little prying to get the pump free.
dont forget to disconnect the three hoses on the inside on ski
you will need a impeller wrench/socket and a vise to get the impeller off
just take her apart and take note of how it comes apart and inspect all components
good luck
mud
