Hi all I Am having an acceleration problem with my ski. I just did a motor switch to a bigger body and had it running great. Now I am having issues with acceleration. The ski will start to gain speed then slow down and won't hit higher speeds. It is driving me crazy. I have replaced all plastic and or rubber lines, spark plugs, checked the wear ring, solenoid,checked compression,and mpem. The only thing that I have done to it is I added reverse but when i took it out right after installation it was running fine. I am so confused. I did a full check and rehaul or the motor and starter right before I switched it over and the motor was running great in my old ski. I had this problem before I replaced everything and took it and had over 600 dollars of work done to it. Hopefully it is something stupid that just needs to be adjusted because of the transfer. If any one has any suggestions I would greatly appreciate it. Thanks.
