Schnit1993
Hi guys i was having problems with my 2008 rxtx not starting and then stoped on me in the bay and had to get towed back. So i would plug the dess in and press the button and it wouldnt start i would rock the jetski around and hit it in a few spots then it would work, this was while i was at the bay's boat ramp, anyway took ot out once i got it started and it would die randomly but start up after a few hit and trys. But then it did it and wouldnt start so had to get towed back. I tried plugging the dess in and powering the started lead and it would start for a few seconds then die. Got it home and same thing would happend. Then i noticed with the dess no connected it would turn the dash on and off every 10 seconds or so with no beeps tho obviously coz the dess wasnt on. Had no idea what it could be, tryed all the usual and nothing so i decided something was obviously shorting it out so started unplugging everything the could be unpluged on the engine and also unpluged the dess post and start and trim button. Got everything unplugged and it was still doing it. So i unbolt and undo the clips on the fuse boxes and shake them and little to find all water starts coming out of the rubber cases around the wires. And sure enough it stops turning off and on.
So to think about it now seadoo and there stupid not water tight black casing they put around the random groups of wiring are holding water where they loop down and up and shorting them confusing the computer and switches, so so advise for people if they have similar trouble. I thort it was the classic starter solinoid but its perfectly fine after finding the wiring problem.
I am now going to remove all the black casings under/behund the fuse box and have just little cable ties to hold the goups of wires together so no water gets trapped and shorts wires, stuffs signals up.
Also going to do the same on the other possible cables the water could sit and not drain out of.
Cheers hope this helps with anyones troubles
