KyleB
Hey guys I think I may have messed up something on my 96 XP. I rebuilt the carbs and while I had them off I wanted to check to see if the rotary valve were turning properly. I removed the plugs and while they were out I decided to check to make sure the cylinders where operating properly by placing a pencil in the MAG cylinder and hand turning the drive shaft until I found TDC. While doing this I noticed the rotary valves turned and I continued to turn the shaft a couple of times to see if the valve continued to turn and it didn't. My question is, how many revolutions does the engine make before the valve turns. I did notice a clicking sound about every 1/2 revolution of the drive shaft. I know this is probably not very clear but before I put the carbs back on I just to make sure everything is ok with the engine. Thanks for any and all responses.
Kyle
Kyle
