Plastic nozzle in Crank
Another good idea 68, Ill give it a try tonight. Thanks for all the input guys, one way or another its gonna come out, it's become personal now. I might even get one of those borescope things, seems like a fun tow to have. Nice conversation piece around the tool box/beer box.
I'll post how it works out.
Plus, if you ever decide to offer low cost colonoscopies from home, you'll be good to go lmao. They are cool tools to have though, saved me the trouble of pulling heads from motors many times.
pmsl i seen these tools at a local tool shop over here i think there a great idea u can find those bolts that fall down under the engine mount yes i think we have all dropped a bolt :lol: u could stick the camera down the spark plug hole inspect pistons for proper carb settings and carbon build up
I'll be heading to Home depot in the morning.
Gave it another effort tonight with no luck. I used 68's grabber idea, but the biggest problem is I cant see it so I fished around trying to feel it, thinking I could grab it...............no luck.
I see that harbour freight has one as well, has anyone used either of these? The HF one is on sale for 89 the HD one is 139 not sure if the extra $$ is worth it.
Shop vac with a long regular soda straw duct taped onto the the end of the narrowest nozzle has always done the trick for me before!
Sounds redneck i know!
That snare idea is AWESOME..... Always wondered what to do with the 5 ft of welding wire that is wasted when my spool runs out. PROBLEM SOLVED....
68ragtop Ill give you 40% of whatever I make selling those little gizmos :)
Saw this at Lowes today and thought of you.
Thanks for the thought, I have all that stuff and still no luck. Did the straw attempt on the shop vac, as Rosie suggested, could not seem to get it. Still cant visually see it, so I have no idea where it is.
Tried buying a inspector scope camera at home depot, but they only had the Millwalkie one which was $350.00 and couldnt justify it. They carry a Ryobi for $149 but its on backorder.
Might have to jump the ditch and try the $89 from HF.
Without visually seeing the little sucker it is near impossible to retrieve.
Kicker, did you pull the RV cover off yet? I would think with that removed & the spark plugs pulled, you should be able to hand rotate that crank & get that bugger to show up . The only way I suppose it wouldn't is if it somehow got between the crank & block near the bearings. But, its gotta be there. I have a snap-on BK6000 it has a really small camera head & a 90 degree mirror. The mirror has been handy at looking around a corner.
That's not safe. The motor in a shop vac is open. if there is fuel down there... it could ignite (blow up) in the vac.
68, I did pull the RV cover off, but it still leaves me with only 2 holes to look through. I think your right that it is wedged in somewhere.
It was never a problem turning it by hand. The problem is getting it to surface. I think getting a camera is the only option now.
Doc your right, I would not recommend for anyone to do anything with a shop vac and fuel together.
It was never a problem turning it by hand. The problem is getting it to surface. I think getting a camera is the only option .
Sure, that makes sense. I was thinking that maybe you were not turning it over at all for fear of it getting permanently trapped somewhere. I have a funny feeling that it's laying somewhat diagonal in the bottom of the block just teasing you.
ive always loved my shop vac with a extention tube on it, if that doesnt work the pickle grabber with ducktape sticky side out always works for me in the long run...
I HAD one of those get in a 350 when i was first building engines, and believe it or not, it bent the intake valve, and stuck to the top of the piston.... nasty little buggers if you dont remember if you had it on the can or not...
good luck!
Thanks for the tip, that's one I have not tried yet used yet. I will give it a go tonight and let you know. i already have my ''happy dance'' moves planned for when I finally get this sucker.
The nozzle will go in a frame with "plastic nozzle no match for seadoo forum" engraved under it.
Fill the crank case with petrol/2 stroke oil , the plastic will float to the top ( if your damn lucky maybe) and you can hopefully get to it with long tweezers , then remove spark plugs and crank out the petrol . Job done.
I still reakon it's your best bet , even if it doesn't float you can 3/4 fill it rock the motor side to side and the straw will hopefully dislodge and become visible .
In theory sounds good but it doesn't float in gas.
If it were me. I'd try the camera and snear. If that didn't work I'd break out the tools to remove the jugs. The cost of the new gasket is better then the cost of a rebuild!
I know it is just about principle now, but you do realize you could have had the jugs on and off 100 times by now?? :D
If it was summer I would have probably just gripped n rip it.........take the chance. Bruce mentioned that a plastic nozzle took down his V-8, not that I don't believe him, I just can't seem to get my head around plastic taking out metal.
Your right kwik, I can be very stubborn at times. What's holding me back is I just had the thing all apart and this happened in the final stages of assembly, so Im trying to avoid taking it apart again. Camera comes on Monday......failing that, off come the jugs, order gaskets and wait for them to arrive.
After all this I might take the ski on a little vacation and join you guys in sunny Florida.
this was discussed at length on pwc today and the consensus was grip it & rip it. (not my advice but thats what they said)
I would have yanked the engine by now had it on my bench and with a screw driver and a piece of chewing gum and a dental mirror and had that tube out and the engine back in. Stop waiting on the post man. And there is no way I'd run it in my engine. Yank it now you'll be back together by 6 AM.
how much was the camera errr how much are the gaskets i think you've just lost a week off your life from the stress when u could have pulled the cylinder and reused the same gaskets as u havent ran the engine yet ;)
By no men's would I grip and rip it or suggest that to even be an option
That's a piece of plastic that will break and melt. You will blow your engine from running it with that in there. Then when you open it up to rebuild it will be stuck to your jugs, crank and what ever else it it came in contact with.
I didn't know this was a fresh rebuild I missed that part of the post. If it was me I just would have yanked yanked the mother and pulled the jugs as soon as it happen.
Not sure who suggested running the ski with it in there but make sure they advise me on any problem!
