View attachment 1998 Sea Doo Sportster 1800.pdf
http://partsfinder.onlinemicrofiche...72&b=14&c=0&d=-PROPULSION-SYSTEM---DRIVESHAFT
So after trying to get the dealer to recover from selling me a broke boat I could only get them to come up with giving me $250 in parts for my 98 Sportster 1800. I realize that the parts will add up over $250 but he said if he can get it at cost he will give it to me for the same price.
I would like some help in a parts list to help figure out the cavitation, I don't need new wear rings as they have zero hours on them.
1. Can someone give me a part number or suggestion of Solas Impellers. I looked on their website and I don't see my boat in the product list. They have a 98 Sportster 1800 but only show a 720 motor and I thought these come with a 717.
Solas Part number is for a XProp : SD-SC-X(16-23)
2. I also want to get any seal that would help seal the hull/impeller shaft and include the carbon seal but I don't know all the part numbers or technical names to help order the parts.
3. I also want to order the Mikuni carb rebuild kits but I don't know if I need all the extra gaskets and what rebuild kit to get.
4. I want to replace the "grey fuel" Tempo lines but not sure what they are and what parts to order.
5. I see it is recommended to make sure the oil pump is adjusted properly, so that is something I need to research but I think there should be some parts to replace on the oil injection system such as new lines or something that typically needs replaced with a 16 year old Jet Boat.
6. My exhaust bellow or whatever is called is leaking water at a welded plug by a fitting, so as a welder I should be able to weld that up without a problem as it looks like cast aluminum.
Thanks in advance for all the help.
