I am working on a 1998 GSXL with the silver engine. Just bought the ski and the previous owner had the engine rebuilt. While looking testing it, presale, it had issues starting but I attributed it to bad gas and after several attempts I was able to get it started. Today I went to test it again while I was doing other work and it is having issues again.
When I go to start the ski it will crank for a split second and then stop, the info center will go out and come back on as well. The buzzer and dess seem to be working, the battery is at 12.5 volts and the plugs are new. I pulled the plugs to try and crank the engine without them in but the same thing occurs. I tried to jump the posts on the starter relay but nothing happened, not even sparks from what I could see. Could this be any thing other than a loose connection?
I dont think its the relay,starter, switch, dess, or mpem since it seems to try and start, and I did get it to start a month or two ago. When it comes to the wiring it seems as though someone did some bad electrical work on the ski. The power wires and ground have copper or brass looking connectors which I dont recall seeing on other skis (little specs of green are actually developing on them) and there is a good amount of electrical tape near the connecters (leading me to believe that this is not factory work).
Finally, were does the ground from the battery attach to on the block? I looked at a manual online and it seems that it should be connected near the starter but mine is connected to one of the bolts on a RAVE valve housing, any one else have this?
Thank you
Thank you
