oil pump cable 97 GTX
dlprint
97 gtx 787 ...
I am attempting to re-connect my oil pump after a motor change i tried premix/bypass. long story short, going back to stock, got a pump with the cable attached to the pump, HOWEVER ... can't for the life of me see WHERE it hooks up on the carbs. There is a plate for the throttle and choke cables (choke gone away due to primer kit)
I am missing something or loosing my mind or a little of both :-)
Any photo's, diagrams, advice would be GREATLY appreciated.
Here is a photo I hope will help. The cable for the oil injection is on the right just below the yellow oil lines that run to the carbs.
After i reread your post, I realized my mistake. I took another picture from the back where the cable attaches. It was hard to get a picture, but here is the best I could get. The cable loops around under the carbs to the back. To give some perspective, the gray on the center left is the PTO cover.
Good luck.
