BP could be the looking for you, you know the magic cure there was discovered by a person here - a wedding ring placed on there and she will stop putting out. This is the inner crank seal which it sounds like you already have knowledge of, once the motor goes thru a few heating cycles it should stop, but if you are losing a lot of oil to this problem you could pinch the oil lines when parked or redo the lower end.
