Oil in Bottom of Hull
That is correct but you still have to have a way to provide a supply of oil to the rotary valve.
The seadoos are the only ones I would keep the oil pump as they are super reliable and sip oil compared to premix but its up to you.
Would like to keep pump if possible. I have the two small lines in previous pics replaced.
Questions:
1.What size lines are the two larger lines running to the pump? One has the filter on it one does not. I'm planing on replacing the filter as well. Looks like replacing the one line the runs under pump is going to be a bear!
2. I'm not sure leaks are coming from tank. I see no evidence (drip or run marks) that would indicate that but I could be wrong. With that where is a source for the grommets/rubber gaskets people in the prevoious posts to buy new parts?
I have kept all mine injected and never replaced the larger lines, just the small ones and the filter.
The tank grommet is the cause 90% of the time. They are available through the dealer or online.
