Okay, steam problem solved, parts were missing from the regulator valve (spacer, clamp)
New problem seems to have cropped up recently...
When I was working on it two weeks ago I noticed about a quart of 2-cycle oil in the bilge. Drained it out, cleaned the bilge (pain in the a**) and replaced the grommets on the bottom of the oil tank (seemed to be leaking)...
I haven't taken the boat out since then, but when putting in the regulator, it looks like ANOTHER quart is down there... this stuff is expensive, how do I get it to stop leaking?? The bottom of the oil tank and the lines coming down from it were again oily, so that may be a primary source of leaking, but it has brand new grommets, what else can I do?
