crisso
Hi All
GTX Ltd 98
I have a problem with the Cam,Quad?(many diff names)that the oil cable connects to,down at the front of the motor
The nut that holds the cam is loose and this allows the cable to pull to far and spin the cam.
This in turn allows the cable to release off the cam.
If I grab the nut to tighten it,I can spin it either way because the shaft it is threaded on to,will keep turning.i.e it does not seem to have a 'stopper'.
Before I pull it apart
1.Does the shaft have any sort of keyway to alighn the cam
2.How do you tighten the nut on the cam
3.There must be a setting to sync the throttle and oil delivery.Any advice on this would be great.
Thank you
Pic is of cable,pump etc.
			GTX Ltd 98
Thank you
