jwaterz07
Okay y'all first let me say, please excuse my ignorance in this post. I've never owned a jet ski and kinda just learning as I go. Bought a 2001 GS a few months ago, it was running hooked up to the water hose and ran great. Took it out and completely forgot to check the plugs
Flooded the motor. Got all the water out of the engine and changed the spark plugs, and added some lubricant so it wouldn't rust up. (This is all 5 hours away from home...) Get it home and it will not run hooked up to the hose? It will idle for about 45 seconds dry then die, but as soon as the hose is hooked up (after the motor is running) it will die.
Also had an issue with it not getting gas. The bulb/ filter up front would not fill up with gas. We thought the fuel pump was in the tank (which we've now learned is the baffle/ pickup) But somehow when we lifted it up it maybe released pressure in the tank? And fuel was slowly flowing. Tried it on the water and it will bog out if revved up. Got the carb cleaned. Now fuel will not even push through with a siphon to fill up the filter, etc. Are the hoses maybe not hooked up correctly? If you pour gas/oil mix directly in the carb it will run until that is used up, but that's it
