manicmechanic
Video....
Yeah Dennis, I went to the link too and saw the simple video explanation on the way the stroke works. It does only show one cylinder, but the easy way to understand it is by looking at a crankshaft. If the two sparked at the same time, then the part of the crank where you attach the connecting rods to the crank, would be equal. They aren't. When you take off the heads to any engine, including the 4-TEC, then you'll notice pistion position is different on every cylinder. Except a V-8 engine. In the V-8, two pistons are up TDC at the same time. But being a 4 stroke, that means, one is at the power stroke, the other is at the end of the exhaust stroke.
Look at a crankshaft you have around your garage. Notice the stager in the area where the pistons connect. By theory, it would be impossible to balance a motor if both cylinders sparked at the same time.
