I just bought my first PWC ever, and it's a 2002 SeaDoo GTX DI. I bought it cheap. Has two issues that I know of:
1. Per seller, it runs well for a few minutes, but then shuts down like the key was pulled. After awhile, you can start it back up, but it will only idle after that. Next day, it runs fine, but does the same thing. Runs great on the hose. (I have not verified this yet)
2. When on the hose, I notice is that it doesn't "pee". Strong water source, screwed in tight.
Because of these two things, I suspect something is getting hot, and making it go into limp mode. Any thoughts or suggestions? It does not seem to be getting even warm when I touch the engine while running on the hose, but I've only run it for 5 minutes at a time, out of fear of the no tell-tale stream.
Also, I made a big mistake... The battery was low, so I hooked up a charger to it last night. This morning, I saw a sticker that says NOT to charge the battery when hooked up to the ski. OOPS! I'm guessing this could fry the computer or voltage regulator? A real dummy move, to be sure.
I know outboard motors, but I know NOTHING about PWC's. Have only been on one once.
Thanks in advance for any comments, good or bad.
