Wiring Diagraphm
We have them here, available to premium members. I've tried to access my manual and for some reason, my Adobe isn't reading the files correctly. The only idea I can think of now that may help you, is that if you were told it was the purple wire, then there should only be one purple wire going to your gages. See where that wire leads and get a multi meter tester and see what the reading on it is at the gages, then at the point of origin. You may find that you have a line break.
I'll keep trying to view the wiring diagraphm. Until then, you may decide to become a member for a month or longer, depending on what your needs will be in the future. Or give me a little time and I'll see what I can dig up!.......
I was finally able to pull up some electrical prints on your doo. Do you have VTS? If so, then the prints are probably the same. They are for the XP....so I don't think there is much difference between the Limited and the regular XP.
It does seem like the purple wire that powers up the gages originates at the MPEM. I'm not really good at the electronics, but I'd say open your electrical box and look for connector #2 and see if there is a purple wire there and if there is, see if there is something broke or loose along the way. I'd probably try a continuity check across the paths. Remember, before doing any continuity checks around the mpem, disconnect your battery wire.
