Ok so i have this 98 GTS was ready to drop in water for test run today when i started it up and heard sloppy noise from the rear. Shut it down started my quest to find the problem after removal of reverse unit and steering i find the issue. the cone for the jet pump seemed loose? Well its was tight but when i moved it around it had play and moved the shaft and prop. After removal of the cone i notice it seems look like metal has seperated from the housing?
So i have a extra jet pump from a 95 HX i parted out so i tore in to that to see if it would work well that housing where the cone attaches 3 8mm bolts is metal not plastic and metal like the 98 gts. :banghead:
Now what would you do to remedy the situation or what are the correct steps to fix this? This is obviously not right.
If you need photos to better describe let me know i will snap ones
thanks
thanks
