ok figured it out now i need to remedy the problem it is alignment
when i tighten the top two 17mm jetpump bolts its fine spins great
when i tighten the bottom 2 lock nuts to just snug im good but if i give them a another turn to make sure good and snug it binds
am i just over tightening everything ? i have tried lifting the front of the motor to maybe reduce that bind when they are very snug but does not change the outcome.
how tight should i make these also these skis do not use the neoprene seal right ? or do they if so i need to get a new one
EDIT
it has all the original spacers in the correct places from the factory
EDIT
