daniellevy1
Thank you for reading and I will really appreciate any advise on this
This is m[video]https://goo.gl/photos/vBbkbvax6MHeqzHB8[/video]y first boat and I was so excited to put it on the water this week but got a LOUD BEEP as soon as I started accelerating.
I've bought a CanDooPro and run a Report today.
I tells me 6 faults. 3 Ignition Coils, Oil level (i've just changed it 3 weeks ago and fill it up) as well as Fuel Pump and DESS line
Does anyone has any suggestions on this Faults. I don't get any "TroubleShooting" suggestions from CanDooPro
THANK YOU VERY MUCH TO ALL THE REPLIES..IN ADVANCE!!
Occurred Faults
1)P0351 Ignition coil #1 open circuit or shorted to ground or to 12V (MAG coil on ETEC2)
2)P0352: Ignition coil #2 open circuit or shorted to ground or to 12V (PTO coil on ETEC2)
3)P0353 : Ignition coil #3 open circuit or shorted to ground or to 12V
4)P1520 Critical Low Oil Level Detected or No oil pressure detected
5)P0231 Fuel pump shorted to ground or open circuit or Fuel Pump relay signal pin shorted to ground
6)P1656 : DESS Post line shorted to Ground
Vin Number: CEC1XXXXXXXX
Total Hours on MPEM or ECU: 144 Hours and 25 Minutes
Last Serviced By: 01748 Serviced on 140930
Last Service: 12 Hours 58 Min
VIDEO of the issue (Loud Beep)
Occurred Faults
