I have a 1998 XP limited with 951 engine. I can't get it started because the starter won't spin continuously but stops and starts.
If the starter does spin the engine it starts right up. But the starter will not spin the engine steadily and consistently. Pushing the start button it might spin normally for several rotations but eventually reverts to cranking a single rotation or two. Sounds horrible.
It's always done this to some degree in the nine years I've had it. Always started eventually until now and even now it starts sometimes.
Here's what I've done so far:
New battery
New solenoid
Three different starters
New Bendix
No voltage drop on cables
Beeps normally
Pulled the pump. It spins freely.
If I jumper across the solenoid secondary outputs the starter/engine cranks fast and normal
If I carefully apply 12v and ground to the solenoid primary coils the solenoid energizes and the starter cranks fast and normal
I have pulled the connector 3 from the MPEM and tested the start switch and it appears to be working well
I pierced the wires to the start switch at the switch end and shorted them together bypassing the switch and the problem remains - erratic cranking
I have continuity from MPEM connector 2 to solenoid primary coil.
Everything in the starter circuit has been tested except the MPEM
Just for grins I replaced all the fuses
It appears that the solenoid is not receiving start signal from MPEM. Is there a reed relay or something inside the MPEM that went bad?
Maybe I got a bad solenoid. I have another I may try.
Thanks for any help.
New battery
New solenoid
New Bendix
Beeps normally
