97ChallengerGuy
1. The boat started pretty easily when I first put it in the water but after I've run it for a while it takes quite a bit of pumping and choking and not choking and pumping and throttling to get it going again.
2. Very poor idle, usually dies. I figure i just need to adjust the idle screw but wanted to list this symptom anyway in case it's all related.
3. While out on the water a couple times had it in full throttle and it stayed at medium rpm/speed then after I would release it and try again a couple times if worked again.
4. Last time after experiencing all of the above, the throttle handle became very stiff?
Any suggestions? I've heard the carburetor
might need adjusted but that can't all right?
