Hello all, first post here. I'm new to PWCs and high powered 2-strokes, but not new to turning wrenches. I've done several diesel conversions, various engine swaps, automatic transmission rebuilds, engine rebuilds, standard transmission swaps, even built a 450 size RC helicopter drone. So I'm hoping my learning curve isn't too steep, lol.
On to my first question. I picked up two matching 1995 XPs. One came with a Factory Pipe already installed. I don't have great detail, but I know the engine was redone after the factory pipe was installed. It had a new crank put in and was bored .040" over from what I was told. After doing some reading on the Factory Pipe, I'm suspicious that it locked the engine up prompting the rebuild. From what I read, running lean due to the stock carburetors seems to be a big cause of this. From what I can tell, this motor still has the stock carbs.
My thought is that, if the motor did lock up due to the factory pipe causing a lean condition, increasing motor displacement will not help the condition in the least, almost certainly making it worse. I took a brief look at the PTO plug and it is more of a coffee color, which is promising, but I want to be certain that the engine is running safe.
How can I verify it's running safe? A short run then check the plugs? If they check out, a bit longer run and repeat? I have a borescope to take a look at the pistons too if that helps.
Or would you recommend I revert to stock? The stock pipe was included. I read that the 720 is a good simple reliable engine stock and as much as I'd love the extra oomph, I'd much rather a reliable 85 HP ski than a 100 HP ski on the edge of destruction.
Is there a sure fire way to run a factory pipe reliably? 44mm carbs?
Thank you!
Thank you!
