If there is water in the engine the plugs will look very clean and white as they get steamed cleaned due to water in the cylinders.
Does the ski still have the Grey Tempo fuel lines? If so these MUST be removed and replaced with new style fuel line. Include the hose between the carbs and replace or MAJOR clean the fuel selector.
The rectifier can stop skis from reaching max speed. Simply unplug it to test to see if this is the issue. Your battery won't charge during the test but it will give you the answer.
