marquisman
I'm working on getting the SPi ready for the warmer weather (if it ever decides to get here), I picked up some XPS jet pump oil, 2-stroke oil, and a battery.
The battery is where my current issue arises. It happens to have the stupidest post design ever thought up for a battery (see image).
Each post has a square nut that has to be held in place while a bolt with the cables is screwed into it.
I managed to drop both nuts and of course they both ended up under the engine. I tried flushing them out with both air and water. No luck.
Any tips?![]()
Sent from my SGH-T989 using Tapatalk
How long are the bolts? If the bolts are long enough, just run some electrical tape around the post, with the nut in position of course. We deal with the batteries at work, that have the shallow nuts that flop around. To fix this, we take a piece of the vent hose(usually comes with battery) and jam it in under the nut.
