I'm thinking eventually I am going to paint yellow parts of hood, but who knows.
Previous owner changed over all the fuel lines so I am solid there. Thanks for the heads up! Anything else of note I should check out?
With a new to me ski, I don't trust the PO to have done anything and/or do it correctly until I see it for my own eyes. So, go over the ski front to back.
-Drain, pressure test, replace pump oil
-Visually inspect wear ring and impellor
-Check/Replace clamps and boot on VTS rod and make sure there is no water in VTS motor housing and spray with corrosion inhibitor
-Grease driveshaft mid bearing
-Test/verify battery is in good condition and replace if necessary
-Replace any grey fuel lines that carry liquid (vent lines are ok to leave)
-Verify water separator screen is clean as well as carb internal filters are clean
-Replace oil injection lines from pump to intake port (if still oil injected)
-Replace oil injection pump filter and check to make sure line feeding pump are in good condition
-Verify oil injection pump cable bracket screws are tight, lubed, operates smoothly, and is adjusted properly
-Verify no air bubbles in oil injection lines
Once all that is complete, if the ski is stock, I verify the carb settings are at/ or near factory set points and then take it out for a test run, plug chop, reading, etc to verify I'm not running lean. Then I usually address any other problems like non-working fuel gauge, etc.
Anyone else please feel free to chime in, Im sure I missed something.
